Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I'm so glad I found this site... Now I can get some sleep, because my problem is solved..."
Geography
eggsontoast28 (Mechanical)
20 Jul 12 12:24
I am trying to find some reasoning/history on why the equations to calculate for Principle Stresses have changed from the Section VIII Division 2 1995 edition to the new Section VIII Division 2 2010, 2011 addenda edition.
Primarily the use of the Natural Log to calculate the Hoop(Circumferential) Membrane Stress in a shell.
I am comparing my principle stress calculations using the 1995 edition with the 2010 edition and the new code returns a higher principle stress.
Any light shined on this would be appreciated.
vpl (Nuclear)
20 Jul 12 16:01
Perhaps because there's 15 years between the two editions. There's been a lot of changes in methodologies and materials in the intervening years. Actually, there were a lot of changes made between the 2007 and 2010/2011 versions. You'd have to find a Code committee member, several of whom frequent these forums, but the main reasons seem to have to do with allowing thinner materials to be used.
By the way, I noticed that you posted both your questions in two different forums. You might want to look at the forum policies, in the FAQ following my signature.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
TGS4 (Mechanical)
23 Jul 12 12:48
Because the natural log equation is more accurate, especially over a significantly larger range of D/t ratios.
As vpl pointed out, the 2007 Edition of Division 2 was a major rewrite. Everything was changed. I would recommend that you refer to ASME PTB-1 for a thorough discussion.
Close Box
Join Eng-Tips® Today!
Join Us             Close
