Creating a Name in Python for Abaqus
When I run my program I would like to create names in the Model Space of Abaqus other than Part-1, Job-1 etc. If possible I would like them to be created based on inputs I add so I can always know what size plate is being run.
For example the generic file name is: p_l_w_t_dec_mat
*p=plate and t=thickness and those will stay the same
*mat would either be A36, A242, or A572 steel and I will make 3 scripts for the different materials so that does not need to change as well.
However, l,w, and dec will change.
say l=20
w=4
dec=0375 (0375 equates to a 3/8 in. plate)
I would want the final results to read
p_20_4_t_0375_A36 and then I would change the p value to s, j, o, etc when it comes to the section, job, output, etc.
Because the input values will change I want the name to automatically update when I change l,w, dec.
THANKS!
Therese
