advise right motor
advise right motor
Hello everybody,
Need your advice. I'm planning to upgrade my air compressor. I have Duracraft air compressor built in 1991 and its time to change the motor.
I want to get a motor with the following specs -
Enclosure: TEFC
Phase: 3
Hz: 60
Frame: 56C
Have looked at Baldors, and found one on here that is compatible https://www.mrosupply.com/product/699088-Baldor_El...
What are you folks using and do you like what you have? what do you think of Baldors? what are the alternatives?
Thanks!
Enclosure: TEFC
Phase: 3
Hz: 60
Frame: 56C
Thanks!
