carbon fiber/350F operating rod/tube
I dont have much experience with carbon fiber. I need to find carbon fiber approx 1.5 od x 1.1 id x3" lg that will keep a strong compressive strength as the operating temp rises to and stays at approx 350F for a few hours. From researching, the epoxy used when the rod is wrapped is what determines the temp rating. So my question is..... Does anyone here know of if a high temp carbon fiber is available in finished rod or tube or will I have to get someone to make this for me? I need a composite type material with a high high compressive strength due to the application. Anyway, If anyone can point me in the direction of a company that may have what im looking for, it would be appreciated.
RE: carbon fiber/350F operating rod/tube
Even with a BMI the ETW compression strength at 350°C/180°C will probably be half the RT dry values. BMI is quite pricey. A 180°C-curing phenolic resin would be a lot cheaper and would probably be almost as good as BMI in terms of strength retention, but the laminate would be less strong to start with.
At 350°F/180°C compressive strength for an undamaged carbon/BMI quasi-isotropic laminate will be about 45 ksi/300 MPa. A more sensible value for preliminary design is 17 ksi/115 MPa to allow for a bit of damage tolerance.
