Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...If I'd only had resource like eng-tips when I was just getting started! I might have dazzled them with my brilliance instead of my BS..."
Geography
drahmatxvx (Structural)
20 Jul 12 6:13
I have some problem for Boundary condition. I need to design support for Inplace condition, The support need to be release in uplift direction and restrain in compression. I have try to modeling the support configuration use Compression Only. But its will ask to put spring definition. And when I check the reaction, there is still have tension force. Can some one help me to solve this issue. I attach sample for Staad Pro Modeling.
Helpful Member!  SethGuthrie (Civil/Environmental)
20 Jul 12 12:21
You are on the right track, but you need to assign some KFY spring stiffness (it can be a large number). When nothing is entered, then a rigid bi-directional condition is used (only springs can be compression only). Review the Technical Reference section 5.27.5 Spring Tension/Compression Specification in the Help for details.
22 Jul 12 1:29
Hi SethGuthrie Thanks alots for your guidance. [smile]
24 Jul 12 22:34
Hi SethGuthrie, Now after we set to compression only support and put define spring, I need to add Support Displcaement on the Joint. When I read the Staad Technical Reference, we cannot combine spring support with Support displacement. I try use another methode to combine support displacement and vertical uplift release by selection compression member only at the column. But the result is not correct. all member ratio more than 100 and there is Warning Shown in the result. do you have any methode to combine between uplift release and vertical support displacement.
25 Jul 12 17:08
That does create a bit of a dilemma. I guess I tend to go with the most direct approach which would be to apply a point load, identify the deflection, then factor the point load to yield the desired support displacement (downward I assume, though I’m not exactly sure how that’s possible in the real world) and then combine that loading with all the other loads in a model with compression only springs.
31 Jul 12 5:22
For this case I use Temperature Load (Strain and Elongation) to replace Support Displacement. And I modeling dummy member and applied compression only. The Support condition I use restrain in vertical direction. When I running, there is lot of warning due to zero stiff, but its still work.
Close Box
Join Eng-Tips® Today!
Join Us             Close
