RISA- Single Angle Compression Members
Does RISA check single angle compression memebers as if they were loaded concentrically only?
IS there a parameter input to let the software know that the angle is being loaded eccentrically?...i.e., connected on one leg only.
RE: RISA- Single Angle Compression Members
The program does have a feature where the user can specify whether the stiffness and capacity of the single angle is based on geometric axis or principal axis bending.
