bridge crane support system columns
Can anyone tell me where I can find the deflection limitations for the support columns of my bridge crane system that I am designing. I see in a lot of examples where there lateral deflection limit for the runway beam is L/400. Thanks you in advance for the help.
RE: bridge crane support system columns
usually x-bracing one bay on each line does the job....try to keep bracing toward the center and don't connect the bracing to the girders.
