Drawing access database
Is there any way i can life link a attributed title block into an Access data base.
As at the moment I extract the information via a script file, the merge all the information together, then import it into Acess.
My goal is to have it so I update the database the drawing'll update and vise versa.
cheers,
cheers,
RE: Drawing access database
If you know VB, you could write a macro that should be easier than a script routine. You would just get the Access object and the Title Block reference and push and pull the info to Access. I know this is a real general answer but it may be the easiest in the long run.
BU
