Steel Erector Certification
does anyone know the ramifications of using a steel erector that is not certified by AISC, specifically does not have a "CSE"...
in this case the steel fabricator is also doing the field steel erection.....
thanks for any insights...
RE: Steel Erector Certification
The problem is, unless your job is pretty large, it's hard to impose the certification on the General Contractor. The AISC certified shops are typically pretty big, but if your job is small, it's hard to get their attention.
We have it in our specifications, but typically don't enforce it.
