Flexible Body Dynamics
I am using NX 7.5 in native.
I am going through the CAST training for Motion simulation and trying to work on the Flexible Body Analysis. I am having an issue with trying to create a flexible link. I cannot seem to select the Flexible Link command on the toolbar because it is grayed out. I have already meshed my part and ran the solution for SEMODES 103 - Flexible Body. I am now back in the Motion Simulation and trying to enable the Flexible Body Dynamics under the Advanced Solution Options in the Environment window. When I select the Flexible Body Dynamics option and click OK, the Flexible Link command is still not available to select. It seems like my Environment settings are not staying when I click OK.
Has anyone else experienced this problem or may know what is causing this?
Thanks for your help.
RE: Flexible Body Dynamics
After 1.5 hrs at phone, the problem here is that the Flexible body module require an extra license from Siemens....hard to believe.thumbsdown
