Intelligent pigging
Intelligent pigging
Dear all I do finished the gauging of 20 inch pipeline the problem is I have a small deflection in the gauging plate I am afraid that the launcher dimension is not correct I need to know what is the intelligent pig dimension especially to make sure that my 24 *20 inch reducer can pass it or not
RE: Intelligent pigging
Note, in the standard, there is nothing that governs minimum ID of a reducer.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
If it ain't broke, don't fix it. If it's not safe ... make it that way.
This should not pose problem for a 20" pig, but do check with pig provider.
thanks for your help
