Interpretation of AMS 2681B para 4.3.2
AMS 2681 B para 4.3.2 states that "For Procedure Certification: Not less than three welds for proeceudre certification representative of each joint in the part or assebly. When test welds are made on actual hardware, one part may be welded for procedure certification". Do you interpret this to mean that if we use a test joint that is only representative of the actual joint that we are required to have at least three welds performed, however if we use an actual part we only need one weld performed?
RE: Interpretation of AMS 2681B para 4.3.2
I would not make that interpretation.
I do not have the text of the standard available, but to me the first sentence should be able to stand alone. That is, "Not less than three welds for procedure certification representative of each joint in the part or assebly [sic]" is a statement that must be satisfied. The next sentence, "When test welds are made on actual hardware, one part may be welded for procedure certification" allows a test weld to be made on actual hardware, but does not change the number of test welds required for procedure certification.
rp
