Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...you guys have given us a way of asking a question and getting some very timely feedback from other users so we don't have to re-invent the wheel time and again..."
Geography
mxracer17788 (Materials)
18 Jul 12 12:48
Let's say I have a 1" diameter 1018 Steel Rod Coupled to a nut made of gold. If the setup is kept in a constantly replenishing salt water bath (3% NaCl), is there a way to calculate the theoretical mass loss of the steel rod after a given amount of time?
EdStainless (Materials)
18 Jul 12 12:51
Put the two pieces in the solution uncoupled but close and measure the current flow. Amps (actually nanoamps) are electrons and they will be exchanged for metal ions. Basic electrochemistry.
Plymouth Tube
18 Jul 12 13:18
Can I just use a galvanic series to approximate this current ?
Zinov (Aeronautics)
18 Jul 12 23:04
use farady's law for corrosion,
cloa (Petroleum)
19 Jul 12 8:47
If you want theoretical not actual measurements then you need the polarisation curves for gold and steel in 3M NaCL which give current per square centimetre (specific current) and voltage- where they cross gives the specific current then times by surface areas to get real currents and use Faradays's Law to get metal loss. Since the bath is constantly refreshing the curves would be fine as given- if not refreshed then the solution will change to iron chloride and sodium chloride and no longer be valid. I assume constant aeration.
Close Box
Join Eng-Tips® Today!
Join Us             Close
