Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks a lot Mate! I can't tell you how many times your site has saved my "rear". hehe..."
Geography
Keyser520 (Aerospace)
18 Jul 12 11:39
If I want to use a wildcard in a rule, such as :
If PartName==*bolt* Then
How would I do that?
Does it use regular expressions?
DBezaire (Automotive)
19 Jul 12 13:26
The wildcard * will not work as it is a valid string character. You can create a reaction to do what you ask.
You need to create a String Parameter String.1 and a Boolean parameter Boolean.1
Create a reaction to fire on ValueChange of String.1
let Name (string)
let Name_len (integer)
let Item (string)
let Result (string)
let Item_len (integer)
let len_diff (integer)
let i (integer)
/* Output */
Boolean.1 = false
/* Assignment */
Name = String.1
Name_len = Name->Length()
Item = "bolt"
Item_len = Item->Length()
len_diff = Name_len - Item_len + 1
i = 0
if Name_len >= Item_len
for i while i < len_diff
Result = Name->Extract(i,Item_len)
if Result == Item
Boolean.1 = true
i = i + 1
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
