Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...just the few hours I've spent on this site I have learned a lot. I can now implement features that will be very useful to my company, and some of those I never knew existed..."
Geography
TheRealDeal55 (Automotive)
17 Jul 12 16:37
Attached is a machined rotor that is rolled back to the cutter dimensions.
This item will not update because some dimensions are not connected (color is brown)
What would cause this, and what would be a solution?
Thanks in advanced.
TibiX (Mechanical)
18 Jul 12 1:02
Hi TheRealDeal55,
If you want to analyze your sketch I would recommend the "Sketch Analysis" tool (Tools menu -> Sketch Analysis) and then go to the "Diagnostic" tab.
Hope this helps and best of luck!
P.S.: I think that you changed a dimension that "upset" another feature (filet or chamfer) or... your dimensions are incompatible between each other (ie.: a cylinder's height is specified by two dimensions not equal to each other.)
TibiX (Mechanical)
18 Jul 12 1:10
I forgot to mention that the "Geometry" tab has a "Corrective Actions" set of button... you should check them out as well.
18 Jul 12 10:00
Thanks TibiX! You were right about the extra dimension.
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
