Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I'm a freelance consultant, and your site's helped me with many issues. I just wanted you to know that someone does appreciate the intelligent help your site offers."
Geography
Carolus17 (Industrial)
17 Jul 12 11:21
I'm new to Solid Edge ST4, I need to draw a "one compartment sink".
anyone have example or tutor how to draw the round corner ?
thank you.
kjoiner (Mechanical)
18 Jul 12 13:40
Carolus,
Are you referring to the fillets on the sides and bottom of a sink? If so, use the round tool and pick the lines on the vertical sides and also the lines at the bottom. The rounds will intersect creating the rounded corners.
Kyle
18 Jul 12 16:25
humm...I do a quick check, i can't find the "round tool". I will try it again tonight,
Thank you so much.
KENAT (Mechanical)
18 Jul 12 16:52
May be hidden under the chamfer button - I can't remember with the newer interface.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
19 Jul 12 9:12
Yes, if you are running ST4, it will be in the Home tab in the Solids group. There is a command finder at the lower right of the screen as well. If you type in "round" it will highlight and flash the command in the tool bar. It's great for new users, but I have used it several times myself while getting used to the new interface.
Kyle
Close Box
Join Eng-Tips® Today!
Join Us             Close
