How do I change Font in Page Editor Module
I am Having some difficulty changing the font when selecting a column from the column list and placing it in a spec sheet. Is there a setting some where within INtools to set this or modify it?
RE: How do I change Font in Page Editor Module
Rob,
Double tap the column you just placed, it will open up the properties dialog, you can set the font properties here.
Regs
