Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It is good to know that there are groups such as this willing to share knowledge in this money driven economy..."
Geography
princed90 (Aerospace)
17 Jul 12 9:19
Can someone explain what the differeces are between the two examples in the attachment?
I'm being told that there are no differences.
Also being told that the projection callout is incorrectly applied.
Helpful Member!  pmarc (Mechanical)
17 Jul 12 9:43
Yes, there is no difference between the two - this is a special case when composite FCF (lower frame in your example) and multiple segment FCF (upper one) are equal in meaning.
Projected tolerance zone height is applied incorrectly only because there is a line separating P modifier and .070 value. It should not be there.
Helpful Member!  Belanger (Automotive)
17 Jul 12 10:15
One small addition. There is no difference ... as long as datum A intersects the features (usually A is perpendicular). But if for some reason datum A were parallel to the axis of the features, then there is a difference between the two callouts, since there would be two relationships to datum A: orientation and location.
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
17 Jul 12 12:47
Thanks pmarc and Belanger.
Since there shouldn't be a line between the P and the .070 should there be a line between the .001 and the P?
CheckerHater (Mechanical)
17 Jul 12 14:10
No line before, no line after.
Also, as projection tolerance essentially applies to part of the fastener (or gage) protruding above the surface of the part, you may consider using (M) modifier with .001 tolerance as well.
pmarc (Mechanical)
18 Jul 12 14:48
Good point, J-P.
I should have mentioned that at the very beginning of my reply.
Close Box
Join Eng-Tips® Today!
Join Us             Close
