Bearing spread in case of angular contact bearings
Experts,
I have a doubt regarding how do we take spread in case of single row angular contact bearings?
Any information regarding this would of great help to me.
Thanks ,
Anoop
Thanks ,
Anoop
RE: Bearing spread in case of angular contact bearings
2 - If it means endplay or float, we can give you some ideas (EASA has a lot of info). In simplest form, usually you just move the shaft over it's limit of travel and measure. But it can be tricky. Would help to know the exact bearing configuration (how many angle contacts, are they back to back or duplex, how is upthrust handled)
(2B)+(2B)' ?
(2B)+(2B)' ?
