Ball-in-socket contact
Dear all,
I am looking at a problem which involves the contact mechanics of a ball in socket joint. I have been using Hertz theory and Timoshenko to study the contact pressure between the ball and socket joint. However, I also need to study the contact mechanics between the radius on the socket joint and the ball. From FE results, I know that the contact here is more elliptical and the contact stresses are higher. I just wondered if anyone know of any analytical models/theoretical models which can be used to study the contact when the ball contacts the radius of the socket.
Many Thanks
RE: Ball-in-socket contact
Thanks, Greg Lock, but I am not sure that this theory applies on the edge of the socket, where you have a discontinuity in the contact.
I appreciate everyone's input, thanks.
