C-Axis Mirror
C-Axis Mirror
C-Axis Mirror
I wonder if it is possible, to mirror CNC(5-Axis) C-Axis (for 180°) when I am in Manufacturing mode and the tool axis remains the same.
Thanks for your reply
RE: C-Axis Mirror
Could you provide a little more detail on what your trying to do?
Do you want to rotate the tool path 180 degrees? You can use rotate about a line.
What version of NX are you using?
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
RE: C-Axis Mirror
Thanks for fast reply.
I am using NX7.
No, I just want to rotate machine head like on the picture.
RE: C-Axis Mirror
Perhaps not the most elegant but create a copy of the post with the C axis limited by some value (don't know where your C0 is...) so it forces C to stay on the other side. The post will then calculate the complement angle to get there. I hope this makes sense as NX is not in front of me. I do this for trunions to keep them from over rotating about A with impellers.
Bill
RE: C-Axis Mirror
Have you tried the ROTATE command under machine control?
John Joyce
NX6.0.5.3
RE: C-Axis Mirror
Haven't tried yet. Thanks
