Ground Flares
Ground Flares
Ground Flares
Could any of you explain the reason of using ground flare instead of elevated flares...?
Thanks in advance...!
RE: Ground Flares
Ground flares are cheap, mostly used in the desert where there is no danger to personnel and little or no consideration of pollution.
RE: Ground Flares
Speculating:
There's usually a emission permit required for any kind of flare, exhaust, etc at an industrial facility. And usually those permits require you to show that the emissions should disperse to such & such ppm at your property line or fence line. Having a taller stack is sometimes necessary to meet those dispersion requirements.
RE: Ground Flares
Ground flares do not have the impost of a visual impact for many miles around the site. this particulalry a problem when there is a process upset and the flare presents noise and light polution.
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
