Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...A lot of the information I've found at this site would've taken me forever if I'd have attempted to research it on my own. Thanks again."
Geography
syed2364 (Chemical)
16 Jul 12 1:12
basically I'm a piping engineer..but I just wanted know something about the pipe size of the pump suction line..I have few parameters like diameter, flow rate, time , pressure head and velocity. I have to comment whether the given pipe size of the suction line is sufficient enough or not..Can anyone tell me what formulas that I have to use to solve this..
Thanks in advance
BigInch (Petroleum)
16 Jul 12 1:19
You need the NPSHR curve for the pipe. Then you need to figure out how to check NPSH.
If it ain't broke, don't fix it. If it's not safe ... make it that way.
stanier (Mechanical)
16 Jul 12 1:28
there is a lot to learn in dsigning pump suction pipework. Suggest you get hold of ANSI/HI 9.8 for the design of pump suction piping. Also the US Army website has details of pump suction design. you may need to physically model the suction to avoid swirling and cavitation. Even if you resort to FEA analysis there will be a caveat in the report which says it should be physically modelled.
Also these will be useful.
www.mcnallyinstitute.com
www.pumpsystemsmatter.org
www.pump-zone.com
http://www.pumpfundamentals.com/pump_glossary.htm#...
Of course you could invest in Grist http://books.google.com.au/books?id=F6dJ36W-nIEC&a...
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
syed2364 (Chemical)
16 Jul 12 1:55
thanks everyone..
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
