pattern vs instance
pattern vs instance
Hello
Could you explain the difference between "pattern feature" and "instance geometry" in NX8, please?
I know there are several threads about it but it's still not clear for me.
I understand that "create component array" is only for assemblies.
thanks
thanks
RE: pattern vs instance
That being said, the biggest difference is that 'Instance Geometry' creates a single 'feature' which can be edited, but the 'instances' are themselves 'dumb'. Granted, if you created it associatively, editing the master object will cause the copies to update, but the copies are not considered their own features, just part of an 'Instance Feature'. However, with 'Pattern Feature', not only is a 'Pattern' feature created, but each of the 'members' are still features in and of themselves which can be edited individually (based on the parametric extent of the original 'feature').
Also note that 'Pattern Feature' is slightly newer, and is based on a general 'pattern service' toolkit which is also used inside of Sketches (starting with NX 7.5) and will be the basis for the function which eventually replaces Assembly Component Arrays (post NX 8.5).
Anyway, I hope this helps explain what the differences are and how you go about deciding which function to use and where it might work best.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
