SIEMENS GT 94.02
SIEMENS GT 94.02
hello
what will happen if we did not close compressor wash drains when we are starting up the turbine ?
HELP SYRIA
RE: SIEMENS GT 94.02
Air will blow out the drains until you close them. If you continue to run with the drains open you will lose some performance. How much is dependant on the drop in compressor discharge pressure.
saludos.
a.
any one here worked in this type ?
HELP SYRIA
