Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...An excellent site which has quite possibly prevented me from having a mental/nervous breakdown..."
Geography
effects of humidity in polymer processingHelpful Member!
suganth03 (Materials)
15 Jul 12 9:27
Effects of environment parameters(humidity,temperature..) in processing of phenolic & epoxy resin
Compositepro (Chemical)
15 Jul 12 11:31
Ask a more specific question. Books can be written on the topic.
Helpful Member!  blakmax (Aeronautics)
15 Jul 12 17:47
A significant effect of moisture occurs because epoxies (and I assume phenolics) absorb moisture in humid environments. If the resin requires an elevated temperature cure that can lead to porosity as the moisture boils off. Many people think that applying vacuum draws out the steam bubbles, but in reality the low pressure causes the bubbles to expand. The Federal Aviation Administration has an Advisory Circular which sets limits for humidity and temperature for manufacture of composite aircraft parts see Advisory Circular 21-26 para 8a(2) a.
Blakmax
rstupplebeen (Mechanical)
16 Jul 12 16:27
Phenolic resin also creates water and formaldehyde during the curing process which is why bump or burp cycles are ususally used. I have noticed trends with ambient conditions both heat and humidity. I hope this helps.
Rob Stupplebeen
https://sites.google.com/site/robertkstupplebeen/
17 Jul 12 11:33
Hi All.... Thanks for ur reply, currently working in gulf where its summer now, so humidity is too high and vary from time to time....here we r processing phenolic with acid catalyst... In some products we r getting more porosity and in some it was good its not consistant and after curing there are more color differance in the laminates....why so...,
17 Jul 12 11:40
whats meant by bump or burp cycle your referring to curing cycle
17 Jul 12 13:34
Bump or burp cycle is: Heat and clamp the molds, open the molds to vent gas, close molds repeating as necessary. I hope this helps.
Rob Stupplebeen
Close Box
Join Eng-Tips® Today!
Join Us             Close
