Bend line font in section views.
Has anybody found out how to change the line font for the bend lines in section views? When you go to the section tab in a view style for a section view you have the option of turning the bend lines on or off. It's just a straight line. I'd like to find out if there is a way to change it to the traditional view break font.
RE: Bend line font in section views.
After you've created your section view and you've toggled the 'Bend Lines' ON, go to...
Edit -> View -> View Depenent Edit...
...and select the section view and from the 'Add Edits' list select the 'Edit Entire Objects' option. Now in the 'Wireframe Edits' section set the line Color/Font/Width that you desire, hit 'Apply' and then select the curves, in this case the 'Bend Lines' and then hit OK.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
