Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...thank you for the wonderful resource that you have enabled here. It is clear, concise, well maintained and most importantly, helpful..."
Geography
Meesamali512 (Structural)
13 Jul 12 16:53
Dear All,
We have an offshore project of structural repair works in which we have to strengthen the piles using steel plates welded to the tubular steel piles. The tubular steel piles are used to support the composite deck system and the whole structure is entirely in offshore location (about 50m from port). The piles are getting corroded due to sea water and now the client wants to protect and strengthen the piles using steel plates and then later to be coated with PU coating works.
I was reading some online documents in which they've mentioned that the piles (steel) can also be strengthened using FRP material and its easier to apply, more durable and even at times lesser in cost. Moreover corrosion problem can be easily avoided increasing the life of the structure.
If somebody has any info regarding FRP over "offshore steel tubular piles", then kindly share as I want to submit a really competitive proposal.
I have also attached herewith strengthening scheme proposed by the client.
14 Jul 12 9:51
Hi Everyone,
After lot of search I found this link on the internet and I believe their system is closest to what I am looking for. But my main concern is regarding design of this system, its pricing and its installation procedures. If anyone has done any projects of similar kind then Kindly let me know. I am trying to close it asap as we have to submit our bid either with steel jacketing or with some alternate cost-effective system.
Here is the link.
http://www.fyfeco.com/projects/by-segment/waterfro...
Close Box
Join Eng-Tips® Today!
Join Us             Close
