Critical cooling rate AISI4130
Hi everyone,
I'm looking for at CCT diagram containing the critical cooling rate for aisi4130 steel. Does anyone know where i can find this?
or maybe some other way to find the critical cooling rate...
Thank you
RE: Critical cooling rate AISI4130
You can search it on this website:
http://weldcct.nims.go.jp/index_en.html
Note that you should register and press "Enter CCTD" first before you can browse the database. You can browse the diagram on "CCT Diagram Database" below "Engineering".
Hope this is useful.
