A325 Fasteners, Torquing
Hello Gents,
Just a basic question, I am trying to connect modular platforms with 5/8" A325 bolts with A194H nuts. There will be a flat washer on the nut end and a direct tension indicator on the head end. Just wondering if it is ok to apply the torque in the nut end? I assume not because the tension washer is on the head end, but what if we put the washer on the nut end? I still don't think it is possible because the torque may mess up the threading? Would like confirmation with someone more experienced as I am a newbie. =)
Cheers,
Jeff
Cheers,
Jeff
RE: A325 Fasteners, Torquing
I thought everyone used the tension set bolt these days.
Michael.
Timing has a lot to do with the outcome of a rain dance.
Plus a bunch of other caveats.
Good Day!
Cheers,
Jeff
