Canned motor pumps - Stator Liner Leakage
Hi all,
I have a query regarding canned motor sealless pumps. What will happen in case of stator liner breach?
I have understood that stator housing plays the role of secondary containment in this type of pumps.
Liquid entering the secondary containment will be in contact with the stator part of the motor, which is under voltage. Will this destroy the motor windings?
Thank you in advance.
RE: Canned motor pumps - Stator Liner Leakage
http://www.gouldspumps.com/download_files/Technews...
Thanks bimr.
Modern canned motor pump has bearing wear monitor and once the indicator alarm is activated, better service the pump soonest possible. Have seen user use the CBM to check the bearing wear condition. This is big mistake as canned motor pump use hydrodynamic bearings, runs very quiet and very low vibration. It does not have the same wear indication as anti-friction bearings.
