Hole layout table in model
I have another coming from Pro-E to NX6 question.
In Pro, if I had several holes in some random pattern, you could import a spreadsheet with the coordinates. Is there an equivalent?
Also, in this case I happen to be doing this at the assembly level and looks like I have to use the Assembly Cut feature. So I have a 50ft beam with tons of hole patterns and I have to create an extrude with all the hole locations. Seems cumbersome to have to place and constrain over a hundred holes. Please help if I'm going in the wrong direction.
Thanks in advance.
Thanks in advance.
RE: Hole layout table in model
UGII_DRAFTING_HOLE_TABLE=1
Now restert NX and with you drawing open and part displayed in a view you can see the holes, you go to...
Insert -> Table -> Hole Table...
...follow the dialog steps and the status line prompts.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hopefully future enhancements will tag the holes with a number on the screen, so you know exactly which hole you are editing in the spreadsheet.
Hopefully you can upgrade soon enough to help you out.
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Budde Sheet Metal Works, Inc.
305 Leo St.
Dayton, Ohio, U.S.A. 45404
Tel: 937.224.0868
Fax: 937.224.1356
http://www.buddesheetmetal.com
