Best way to remove hot dip galvanized coating?
I have a bolt that is HDG and I would like to remove the zinc layer to look at the cracking under the microscope. What is the easiest way to remove this coating without damaging the base metal?
RE: Best way to remove hot dip galvanized coating?
