Advanced Simulation, Fields
I am using pressure Fields in an FEM that I have. I add a spatial pressure field to the sim (Insert->Predefined Table Field->Spatial Pressure…) and import the data from a file. If I choose Delaunay - Accurate it takes forever for the field to calculate (still going actually...). I don't really care as long as it needs to only be created once, but from what I have seen NX recreates the interpolator whenever you open the file. If I open the sim it will say "Creating Delaunay - Accurate Interpolator for Pressures field". Is there a way to make NX create this a single time? instead of every time....
Jeff
Jeff
RE: Advanced Simulation, Fields
