Mechanical Engineer's Wishlist
So I'm in an interesting situation. My project has an excess of funds, and my program manager has asked me to put together a wish list of equipment for the mechanical engineering team to purchase before the FY is out.
Problem is, we're fairly well equipped as it is. The type of work we do is quick design, modification, and prototyping projects to get stuff out to our guys in the field quickly. We manufacture most of our own stuff in house in low quantities. Here is what we currently have in addition to a well stocked standard toolbox:
CNC Mill and Lathe
Eden 500 3D Printer
Benchtop Mill / Drill
HALT/HASS Chamber
Bandsaw, Grinding wheel
Mobile A-fram crane
ANSYS Mechanical with CFD
Solidworks Premium
MathCAD, MATLAB, Labview
IR Camera
I'm thinking about picking up a FARO arm for QA and reverse engineering, and maybe some more instrumentation for field testing.
So, given what we have, what kind of cool / useful stuff would you guys put on your wishlist?
Thanks!
CNC Mill and Lathe
Eden 500 3D Printer
HALT/HASS Chamber
Mobile A-fram crane
Solidworks Premium
IR Camera
Thanks!
RE: Mechanical Engineer's Wishlist
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Tobalcane
"If you avoid failure, you also avoid success."
“Luck is where preparation meets opportunity”
What would you do with stereolithography equipment? MEMS type work?
computer equipment
a scanner/faro arm/ CMM is nice to have. If you want something to work in the field look at something like the Creaform scanner. Don't forget the software like Raindrop Geomagic.
Tobalcane
A small manual ("tool room") lathe with a grinder attachement could be handy - for grinding form tools, sharpening cutters, and the little odd jobs that are just too small to warrant cranking up the CNC. It's also easier to fit vacuum pickups and cleanup a small lathe (and less costly when they eventually break due to grit getting into everything).
Waterjet cutter, laser cutter, CNC plasma cutter...depends on what materials you work with the most (waterjet is probably most versatile, but most $pendy).
Welding equipment?
Heat treat furnace?
Injection molding machine?
Investment casting foundry equipment?
Good parts washing equipment might be important, depending on what you are building...but likely not as you don't list a laminar flow bench in your existing list.
PDM/PLM system and it's implementation?
Dedicated high speed CAD server & network if PDM/PLM isn't an option.
Newer PC's with more RAM and better graphics?
Well, I warned you that it was going to be biased
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I omitted it from the list but I just added three more monster CAD/simulation workstations to the network, so we're good on machines.
Again, we're almost completely out of lab space, so if we're going to buy equipment it needs to be benchtop size stuff. If I could buy lab space then I'd buy an injection molding machine in a heartbeat....
And the engineer in me says the obvious answer is to just spec a few high dollar items that don't take up much space, and hold their resale value well.
Marginally more realistic, surface profilometer if you often care about surface roughness.
I guess the real question is what frequent tasks do you currently have to sub out or do work arounds for etc. where you could benefit from performing the function in house?
The trouble with a Faro arm is that it takes a fair while, and continual practice, to come up with even half reasonable accuracy, at least on cars. Across a car I'd be pleased to get +/- 1mm repeatability from a Faro. That's good enough for practical purposes, but it isn't exactly the impression you get from their comics.
Cheers
Greg Locock
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems." -Scott Adams
Doug
A.
Cockroach
More accurately, a UPS-battery backup power supply (supplies!) for the tools, AND for the office PC/copier/fax/telephones/thermostat equipment.
We had a power surge at the house when the new" green eco-monitoring power meter lost connection to the incoming main leads. The short blew every electronic item in the house: clocks, TV, playstation, digital coffee maker, microwave, AC controller, digital (zone) heater controller, refrigerator, VCR, and every surge protector.
The PC's and scanner/copier - which were on their UPS's and so isolated - came through just fine.
- Steve
The 40k rpm high speed mill spindle option was an exotic, extra $ purchase that actually got used fairly often. Also we bought a 4th axis for the mill and a manual rotary indexing fixture, the latter used more often. I came to love the set of insert cutters I bought for the CNC mill.
We were always borrowing the QC departments' measuring tools:
digital height gauge, oversize digital caliper, multi-size digital micrometers, ceramic gauge block set (very useful), shadow graph profilometer (probably too big for your benchtop limit), large granite table, angle plates.
Occasionally we needed to buy in exotic raw materials, strangely they always had long lead times: PEEK rod, tefzel, ceramics, titanium, etc.
The ultrasonic bath cleaner was used daily.
