Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have found your site brilliant. What makes it good are the people that contribute to the site..."
Geography
ajk1 (Structural)
12 Jul 12 8:39
1. Does anyone know of a form release agent that has been shown to sigificantly reduce bugholes at formed surfaces?
2. Does self-consolidating concrete generally give a somewhat sandy surface finish? I have been told by a forming contractor that if I do a round column with plastic-lined sonotube type form or steel form, it will not give the normal "shiny" type finish that is obtained with normal concrete (he says though that he has used a specially designed self consolidation concrete that did address this).
Ron (Structural)
12 Jul 12 9:01
ajk1...
1. No. It has more to do with the development of laitance at the formed surface, a function of the concrete mix, not the form release agent.
2. Self-consolidating concrete has a higher sand ratio, so stands to reason that you might get a more sandy texture; however, against formwork, there should be no real texture other than the smoothness (assuming smooth formwork) of the concrete and a reflection of the forming surface. Excessive laitance (wet mix, overvibration) will cause a shiny surface, particularly with plastic lined forms.
ajk1 (Structural)
12 Jul 12 10:18
Ron - I seem to recall that there was a paper published, perhaps in ACI CI, about research study with trials with different form release agents, in which it was found that certain types produced more bug holing than other types. Maybe I should see if ACI has a forum that might lead me to that.
In any event, is there anything specific that we can specify about the concrete itself, or the placement method, in vertical elements (columns and walls), to reduce bug-holing?
Helpful Member!  shobroco (Structural)
12 Jul 12 20:12
I designed a building that had site-cast walls with decorative (split-faced vertical ribs) plastic form liners. The ready-mix supplier convinced the owner to buy a self-consolidating mix instead of the standard mix that I had specified. The finish was beautiful, smooth & glossy, and the concrete shrank so much in the first couple of months that the caulking lines on the cracks look like another decorative feature.
ajk1 (Structural)
12 Jul 12 21:48
Shobroco - I appreciate the actual experience - ok, but this would likely not happen with a column
Ron (Structural)
13 Jul 12 6:08
ajk1...if I recall correctly, the problem with some form release agents was a surface reaction creating air bubbles...wouldn't want that. I'll see if I have that paper.
Close Box
Join Eng-Tips® Today!
Join Us             Close
