ONLINE FIRE PUMP SELECTION!!
Can Anyone help me in selecting the Fire pumps online. I have one link mentioned below but I want some other make for Fire Pumps. Your quick response is much appreciated.
https://rcwapp.xyleminc.com/fp_select.asp
REGARDS,
ADNAN...
REGARDS,
ADNAN...
RE: ONLINE FIRE PUMP SELECTION!!
Armstrong pumps require you to register for the selection software: http://www.armstrongpumps.com/softwarelibrary.asp?groupid=8
Arora has an online selection software that may be helpful http://www.aurorapump.com/
You can also try going directly to the manufacturers rep to do the selection for you.
I don't have any input to your question, but if I may offer some unsolicited advice there are many people on this site who can often help with a reasonable question but won't even open a thread with an exclamation point in the title (let alone two). In over 30 years since college, I have never once found a reason to use that particular punctuation mark in an Engineering document. I don't provide substantive responses to threads that contain them. I am not alone. You will expand your audience if you leave that noise for Facebook.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
Fairbanks Morse has an online program:
http://www.fmpump.com/EngineeredResourcePage_resou...
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
