Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
Thanks so much for having a place for us propeller heads to hang out and chat.
Geography
Assign Frame releases - what does the Program's default values mean?Helpful Member!
SYYEO (Structural)
12 Jul 12 2:24
I'm currently trying out the SAP 2000 to simulate a simplified model for the phd thesis and would like to find out more details about the Assign frame releases portion.
Under ‘Assign frame releases’, if I only check the ‘Release End ‘ boxes for moment 22 and moment 33, and assign a value of 0.5 for the ‘End’ portion of ‘Frame partial fixity springs’:
1) Does the program assumes that the particular frame member is uniform and that the '0.5 release' is set at the center of the member?
2) What does the default ‘0’ value means?
Cheers
engipaul2 (Structural)
13 Jul 12 6:29
1) A non-zero value next to a checked release means that a partial (semi-rigid) connection for the related degree of freedom will be applied. This value should represent the stiffness of the spring for this dof. In your example, it should be the stiffness of the rotational spring about the local 2 or 3 axes, so a value of 0.5 seems apparently too small.
2) Default value zero means that a full release is applied, i.e. rotation is free, thus moments will be zero at this end.
Software for structural engineers
Cross Section analysis and design
Static Analysis of frames
http://www.engissol.com
SYYEO (Structural)
26 Jul 12 5:46
Pardon my ignorance in SAP2000, still got a few more quick questions with respect to your reply on No. 1:
1a. Is it possible to assign the spring positioning at, say middle of the column?
1b. When you mention 0.5 is too small, what is the unit for that input? Could you give me an eg. as to the normal value that we should put in that input box?
Cheers
Close Box
Join Eng-Tips® Today!
Join Us             Close
