Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...it was ingeniously designed and all those clicks were for my own good... and that was even before I got my speedy and useful answer to my tekkie question that I eventually posted..."
Geography
ADCanada (Structural)
11 Jul 12 21:27
Hi to all
Due to space restrictions, is it possible to place the wooden joists directly on an I-Beam without having any wood nailer between the wooden joists and the I-beam, it is noted here that at the end of the joists there is a 2 1.3E LVL's (i.e. the LVL's are running along the I-beam) ... and to restrict the I-Beam from lateral movement an angle is suggested to be welded on the flanges of the I-beam and have a bolt fasten to the LVL's...
Is there any structural problem with that?
BAretired (Structural)
11 Jul 12 23:16
Don't know. Provide a cross section through the beam.
BA
hokie66 (Structural)
11 Jul 12 23:21
I would prefer plate cleats on the steel beam for bolting through the joists.
ToadJones (Structural)
12 Jul 12 8:24
Can you raise the "I-beam" up and frame joists into the I-beam?
woodman88 (Structural)
12 Jul 12 10:56
Yes you should be able to. But you still need to meet the minimum code connections requirements for the joists. Such as hokie66 idea.
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
Eldorado (Structural)
12 Jul 12 11:59
Using cleats (hokie66) or raising the beam (ToadJones) both seem to be good options. If raising the beam is an option, I would use it. I don't know loads or joist depths, but I commonly hold my steel beams down 3" to apply a double 2x nailer to the top flange for accepting Simpson type hangers. The 3" wood nailer is typically a minimum for the hanger fasteners I need. The beam can also be brought up flush with the top of the joists and hangers welded to the top of the beams. If you use a wood nailer, make sure the width is slightly wider than the steel beam.
dhengr (Structural)
12 Jul 12 12:32
You can also pad-out the stl. beam on each side and use std. joist hangers nailed into the padding members. Set the top of the new joist a little higher than the top of the stl. beam. The joist will tend to settle in the hanger a little and it will also shrink perpendicular to the grain. So if you set them both at the same elev. you will end up with a hump in the floor above right over the stl. beam.
MiketheEngineer (Structural)
12 Jul 12 12:32
If I am reading this correctly - done all the time. Many guys use a "cleat" or 1x2 nailer on both sides of I-beam to joists. I have even seen 16d nails on each side of I-beam. Can't say I approve of that - but probably works??
12 Jul 12 18:48
Mike,
Ever tried driving nails into a steel beam?
shobroco (Structural)
12 Jul 12 19:34
Wooden joists are placed directly on beams every day of the week (literally) and the condition is recognized in the OBC by stating that without a wood plate on top (assumed to be bolted to the beam) there must be a cleat on each side of the beam to restrain the top flange. It isn't a great detail for the simple reason that the floor will squeak forever (refer to hokie66's comment).
12 Jul 12 23:56
Wow you guys are great.. this is my first time in this forum and i like it...
From what i read in your comments (i mean all of you) and from what i was researching I apploaded a sketch that explains what are my intentions and what problems i am facing here:
http://files.engineering.com/getfile.aspx?folder=0...
1.The steel beam is the minimum size that can be used due to deflection...and the client did not like the idea to go with an alternative steel beam since it will result in a wider beam.
2. There is a series of 4ply- 2"X12" pressure treated to form the balconies. And below the I-beam there is the balcomny door for the floor below.. sorry (ToadJones) there is no room to play here.
My solution from what i have researched today and to what i was reading on your replies to the thread are
A. Additing a 2"x4" Scabber to help the framer in aligning his 11 7/8" deep floor joists.
B. Adding a steel angle which can be welded on the flanges of the beam, and having the vertical long leg bolted with the 2 LVL's...
From A and B I guess i will be satisfying the minimum requirements for connections.
(shobroco) do you think my detail will still make the floor squeak?
(hokie66)& (woodman88) what is your opinion about the detail?
13 Jul 12 13:30
I would delete the angle, it's overkill for lateral restraint & the wood I manufacturers won't let you notch their bottom flanges to clear it. Specify an adhesive (PL Premium or something) between the joists & beam to stop the squeaks. You probably wouldn't have a problem anyway because your beam is not in the middle of a floor getting frequent traffic, it's at a wall.
msquared48 (Structural)
13 Jul 12 13:37
shobroco:
The verticle angle is placed to the side of the joist and the horizontal leg is faced away from the joist being nailed to it, so there is no notching required.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
13 Jul 12 15:41
Then I misunderstood the OP and the sketch; he says the LVLs run along the ends of the joists, which means the joists butt into it. If so, they sit on top of the angle in the sketch, which is okay as long as the top of the angle is set to height, not the top of the beam. The way I read the sketch the joists are to the left & an exterior deck with joists parallel to the beam is to the right.
13 Jul 12 15:48
I think there is a problem in understanding the intent of the detail. I Joists to the left of the steel beam are bearing on the top flange. I'm not sure of the location of the four 2x12 cantilevered for balcony. Where is the balcony?
The angle connected to the top of beam is discontinuous, right? It is connected to two LVL members, one of which is continuous and the other fitted between joists.
I don't think we are all seeing the same picture here.
BA
13 Jul 12 16:18
It's not the first time that I haven't seen the same picture as everyone else. Ask my wife about the last movie we watched together:)
13 Jul 12 16:46
You have to open your eyes when you watch the movie!
Mike McCann
MMC Engineering
13 Jul 12 16:52
Oh, you've seen that one too.
Helpful Member!  dhengr (Structural)
13 Jul 12 16:52
Since that detail is so well thought out and delineated that several Structural Engineers can’t figure out (agree on) what it shows, it will be interesting to hear and see how it actually gets interpreted and built by the contractor. It is almost always ‘funner’ if there are multiple interpretations for a given detail, keeps the job interesting. You will probably also want to put a drip pan under the 4-2x12's cantilevered balcony beam members since they have such a habit of leaking. Also, use P.T’ed. lumber for those canti. beams and framing below them. Be sure to study the back span support of those canti. beams and pay special attention to their flashing at the ext. wall. Flash the top and ext. face of those beams since water will run back into the building on or btwn. them. The 2 ply LVL’s (bad terminology) are more than likely actually the rim boards furnished to match the I jsts., not actual LVL’s. Why do you need a double rim board at this location, is it doubled along the whole wall?
Why not put the stl. beam up in the same depth as the I jsts.? Put 2-2x10's or 2x12's inside the web (padding) and use std. I jst. hangers to this padding to support the fl. jsts. Trim the rim board, in height, to fit btwn. the two outer flanges so it has its continuity and put a little padding behind it, to the beam web, and bolt it all together every 16"? In that depth/space you can use any beam width you want. Then, frame a light std. header below the stl beam, for the door below.
bookowski (Structural)
14 Jul 12 16:46
Eldorado - Why do you say that 3" (double 2x) is the required nailer for top flange hangers? I'm pretty sure most Simpson specify a single 2x is sufficient.
In general do most people prefer to the top flange hanger to a nailer or packing out the web? If you pack out the web are you still providing a top plate for sheathing attachment?
19 Jul 12 12:48
Bookowski, if a top flange hanger requires 10d nails (3" long), then you don't have enough wood to sink the nails in a single flat 2x.
19 Jul 12 15:21
Why not use joist hangers on double nailer on W460x52 (W18x35 Imperial)? Weight is the same, deflection is much less, flange width is 152mm (6") and it gives better lateral support to the top flange. Would need to fur down about 3" to window head.
BA
19 Jul 12 15:46
Simpson used to have top flange hangers that were heavy enough that they could be welded directly to the top of a steel beam.
Mike McCann
MMC Engineering
focuseng (Structural)
20 Jul 12 0:36
simpson still does. I think they even have handy weld sizes. I know USP does. You have to look at the "custom" options in the back of the catalog.
Eldorado is right. Every once in a while I get one of these flush steel beams from an Architect and I get a nice 1.5" plate. Unfortunately the larger beam flust with the typ. joist need heavier duty hangers. Then I get to spec a custom height hanger which gets welded direct to the steel.
MAP
20 Jul 12 1:01
Welding on a wood job is not a good idea. Use joist hangers with a nailer.
BA
20 Jul 12 13:06
Weld any hangers before wood installed. Top mount hangers go in before the joists are set anyway. Sometimes you just can't get the config to work without it. I've seen more burn holes from the plumbers than the steel erector.
MAP
Close Box
Join Eng-Tips® Today!
Join Us             Close
