Expert Witness vs Building Inspector
I am a expert witness on a very large house that was not issued a final C of O because the contractor was terminated. The building inspector allowed the general contractor to do his own design build. The architect is no longer on the job. What is the Building inspectors exposure allowing the contractor to disregard the Architects plans. The GC's workmanship is a million dollar disgrace. Any tips will greatly appreciated.
RE: Expert Witness vs Building Inspector
From one AHJ website
"Building Inspector I/II
Education:
Equivalent to graduation from high school.
Experience:
One or more years of experience performing work in the building trades of plumbing, electrical, mechanical, foundations, and/or remodeling work. Experience performing building inspections is highly desirable.
Building Inspector II
Experience:
Two or more years of experience performing journey level work in the building trades,"
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
All I know is that I am glad I am not that building inspector. Could be a real can of worms here.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Designed spread footings were not intalled as the steel posts were set on the wall footings where the walls were removed.
Residential construction codes are more "forgiving" than commercial codes, so part of the blame goes there. If an architect or engineer was required to submit the plans, then the contractor is obligated (under the IRC/IBC and state codes derived from them) to follow the submitted and approved plans or the permit is invalid.
Another issue is that CGL does not usually cover a contractor's screw ups or bad construction...only the consequential damage of such. As an example, if subcontractor A screws up and it damages subcontractor B's work, then a claim can be made for the work damaged by A, but not A's work. To further bring this one home, suppose Sub A is a stucco installer and Sub B is a framing installer. Sub A fails to install the stucco correctly and it causes water intrusion damage to Sub B's work. The damage to the framing would probably be covered under Sub A's CGL; however, the defective stucco work would not be covered. An argument would then have to be made that the only way to repair Sub B's damaged work is to removed Sub A's work, defective or not. It gets complicated with insurance coverage.
