Replacement Component causes broken wave links
NX 7.5
I need some help with trying to figure out the best solution for what I am trying to do. Here is a little bit of background. I have an assembly that includes a component that has a complex curve surface, this surface meets up with a plate that is modeled in the assembly file. So currently, we offset lines from the a linked body of the component and offset a certain distance in a sketch in order to match the curvature of the component, and then extrude the sketch to create the plate. We have multiple components that are different sizes and have different complex curves. So we want to have trim sheet bodies in each of the components that can be used to trim the plate solid in the assembly.
So let's say that we have Assembly "C" and components "A" and "B". We have the "Plate" solid in Assembly "C", it is being trimmed by a linked sheet body from component "A". When we replace component "A" with component "B" the linked sheet body is broken. We have tried naming the extrude feature that makes the sheet body the same in both components, as well as the sheet body itself. This doesn't work. The only thing that works is if component "B" is a save as of "A" and you modify the sketch geometry.
Can anyone provide any insight into how we can do this, or if there is a better way of going about what we want to do? I have attached the models I have used to test this.
RE: Replacement Component causes broken wave links
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I just want to cut an assembly made out of two parts inside another assembly. It seems that NX does not do that or I am making a bib mistake here. I'm trying to cut this part using a line extruded and when I click the tool Trim I cannot select the object or the part to start the process of trimming...
Could any one give me guidance? I'm using NX 8.0.2.2
Insert -> Combine -> Assembly Cut...
...to perform the Boolean 'subtract' which will trim away your assembly. Note that the these 'trims' will only occur at the Assembly level, that is the original component parts will remain unchanged and this 'Cut' feature will only exist in the context of your Assembly.
Also, using PMI you can create 'Section Views' of your assembly (or any other part for that matter) which again will only exist in the context of the PMI View.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
