NX convert part units
In thread561-261407: Converting English to Metric (Sound like a "DURRR" question... maybe?) I posted a file that gave an overview of converting part units and finished with instructions on how to integrate that into the explorer right click menu (right click on a part file to convert the units). The attached file is an update; the old version would error out if there was a space character anywhere in the file path. The IT dept. of the company I used to work for kept us in line, so it was never an issue; where I work now is not so strict. This version has been modified to handle spaces in the file path.
RE: NX convert part units
www.nxjournaling.com
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
At least the link below my signature works.
I did some searching around and it appears the this type of functionality is no longer built into windows 7. The only work-around i could find was using a 3rd party tool such as FileMenuTools that allows you to manually set the File Type options as you could in Windows XP.
If anyone knows of a different way to do this that does not require 3rd party tools.
Bruce
NX 6.0.5.3 (NX 8 Testing)
Windows 7 64
Source :
http://pcsupport.about.com/od/fixtheproblem/ht/def...
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
This "Convert to mm" command can be added to the Right Mouse Button context menu for .prt files on both XP and Win-7 without the use of 3rd party applications with the following single line command .
CODE
HTH, Joe
