Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This site is like first coffee in the winter morning..."
Geography
Antnyt23 (Structural)
11 Jul 12 9:58
I'm am new to RISA 3D. I was trying to model an equipment platform for roof equipment to verify the design of the steel beams. I have a row of W8x10's 7 total spaced at 2' o.c. (covered with grating where the equipment will sit) on the north end a W8x10 closes off the 7 other W8x10's while on the south a W8x10 runs approximately 30' where it can catch a column of the rooftop. In the north east corner a W10x12 is connected beneath the W8x10 structure that creates the platform at an angle and connects beneath the 30' W8x10 span. The W10x12 is bolted to the W8x10s at 3 locations (NE corner, last member of the platform and where the 30' W8x10 span ends and is bolted on top of the W10x12).
My issues are I am not sure how to correctly model the W10x12 that runs beneath the W8x10 structure and is bolted at 3 locations. Attached the model I constructed on RISA. I am trying to learn this program and any help and suggestions would be appreciated.
msquared48 (Structural)
11 Jul 12 11:51
If I understand the situation correctly, you model the lower beam as continuus, with the transverse beams as continuous over the top.
You could either have a short dummy vertical members between the upper and lower beams, or frame all the beams at the same level.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
JoshPlum (Structural)
11 Jul 12 18:09
Antnyt -
Open up the RISA-3D help file or the general reference manual. There will be a main topic called "Modeling Tips" with a subtopic called "Modeling One Member Over Another". I believe that this is essentially what you are trying to model. The discussion in the help file / general reference manual says essentially the same thing that Mike said above.... model a small "link" beam to connect the W10 and W8's wherever they are bolted together.
12 Jul 12 12:21
Thank you. Both posts were helpful. I having a feeling I will use this a lot.
Close Box
Join Eng-Tips® Today!
Join Us             Close
