maximal radial load on screw
Hallo!
I want to calculate maximal radial load on M8x12 screw (7mm) made of steel grad 12.8. Does there exist any connection (equation) for this. If yes can you show it!
Thanx
j
Thanx
j
RE: maximal radial load on screw
Cockroach
does "maximum" load mean allowable ?
"connection" implies a brkt, loaed by torque ? in-plane ?? (in-plane torque would be reacted by shear on the bolt). is the bolt being torqued ??
please restate your question !
