monolithic concrete pour for 20x20 ft tank wall
if i have a tank wall 20 by 20 feet, wall 12 ft high. can i pour this monolithic without construction joint?
i will need waterstop if i'll put construction joint.
dont know if i need one though.
can anyone give me construction guideline upto how long can they pour tank wall without construction joints.
thanks,
thanks,
RE: monolithic concrete pour for 20x20 ft tank wall
not base to wall
You may want to put the joint in the middle of the wall rather than the corners.
With a 20' wall, depending on the reinforcing and forming available, you may want to construct it monolythically.
Dik
BA
