G-code, G41 and G42
G-code, G41 and G42
how to use these codes? what do left or right means?
if in turning half a ball (sphere), from 0 to 90 degrees, G41 (or G42) will compensate right?
thanks.
thanks.
RE: G-code, G41 and G42
G41 means the cutter stays to the left of the programmed path.
G42 means the cutter stays to the right of the programmed path.
G41 for climb and G42 for conventional is not always a valid statement, especially on a lathe.
Think of it as driving a car and staying away from the centerline on the road. If I want to stay to the right in the direction of travel by 2 feet, I enter 2 in the offset register and use a G42 to stay to the right of the line. If I want to drive in England, I would use a G41 to stay away from the centerline. :)
Ben Loosli
your judgement?
xx---cor
We use a .012 R tool
G0 X.8563 Z.1
G96 S300
G1 Z.025 F.002
G41 Z0
X.75
G2 X.6131 Z-.0183 I0 K-.137
G3 X.48 Z-.04 I-.0665 K.0913
G1 X.1254
XX-tool
The following G-code requires a .008 tool nose radius. X.766 Z0; G2 X.6112 Z-.0248 R.133; G3 X.496 Z-.040 R.117.
XX--com
Untitled
N4G97S1625M13(FINISH FORM FACE)
M98P1
T0404
G0G99X.9Z.1
G1G41X.85Z.0005F.005
X.750F.0005
G2X.615Z-.020R.125
G3X.48Z-.040R.125
G1X.15
G40Z.1F.2
M98P2
M1
XX-TECH
NAT05(R.BORE)
N0600G97S2500M08
N0601G00X0.185Z0.05T050505
N0602G96S275
N0603G85N0604D.025F0.004U0.008W0.004
N0604G81
N0605G00X0.75
N0606G01Z0G41E0.004
N0607G02X0.615Z-0.02I0.0003K-0.125E0.004
N0608G03X0.48Z-0.04I-0.0678K0.105
N0609G01X0.22
