contact stress calculation for design of pin
Dear all
i want to design a pin and fork assembly, where the header lug is connected to the support rod via fork and pin, please let me know how to calculate the contact stress in pin due to the bearing of pin in the fork lugs.
thanks
RE: contact stress calculation for design of pin
Assume contact pressure over 120 degrees of the pin
For lifting lugs, I use the pin/hole design methods from ASME BTH.
