flexitallic per crush by valve weight?
I have a situation with main steam flange connection. The flexitallic gasket has beeen in place with a 1200+ lb valve on it for weeks with no torquing. Is this a problem when I later torque the joint.
RE: flexitallic per crush by valve weight?
i'd change the gasket before tightening and torquing for final fitup.
