channel welded at its outline
Hi all,
I would like to ask for the issue of welding a channel by the two sides.
I have seen how to do this but only by one side, with only one line of welding in W. Blodget
and websites. But I need to weld by the two sides. So I need to know first how is computed the Inertia by the vertical axis (the complicated one). Because I have tried this but I could not manage to do that.
Thank you very much
Thank you very much
RE: channel welded at its outline
i haveIit but it' not installed at the present.
http://www.engineering-software.com/pr/sku27513.ht...
unclesyd thank you for the program I will use it. But
beside that I want to know how it is computed :)
