Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I've gotten solutions within a day - it saved a lot of time and actually got me one ATTABOY from my boss..."
Geography
alequip (Structural)
9 Jul 12 23:44
Hi, in Australia is there a max length a 5" drive shaft can be? We are stretching a Volvo FM12 , 8x4 rigid and currently have a need for 1 shaft to be 2300mm long witout cutting it and making 2 short shafts. Any advise?
Cheers Paul
GregLocock (Automotive)
9 Jul 12 23:48
what rpm does it run at the truck's maximum speed?
what material is it made from?
Cheers
Greg Locock
10 Jul 12 0:00
Dont know steels tensile, but knowing Volvo it wont be low. RPMS max at max speed is about 2000rpm.
LionelHutz (Electrical)
10 Jul 12 8:21
A drive shaft will turn into a skipping rope as it reaches a critial rpm. I've seen the formulas for calculating the rpm on the internet before. Try a Google search.
10 Jul 12 17:32
many thanks
Helpful Member!(2)  GregLocock (Automotive)
10 Jul 12 19:19
It is not as simple as that. The skipping rope shape is longer than just the distance between the UJs and the inertia of the driveshaft is greater than just the tube because of the mass of the UJs.
So, yes, you will be able to find an equation for the critical speed of a shaft on the internet, but if it hasn't been adjusted to take those two effects into account then it will be misleading, and will overprdict the safe rpm.
I would suggest looking at a book that discusses driveshafts explicitly, a power transmission specialist may have one, the SAE certainly had a driveline manual, but I can't remember if it includes whirl speeds.
You also need to make sure that you run at significantly less than the critical speed, as the resonant peak has shoulders. I'd suggest 30% would be a good starting point.
Cheers
Greg Locock
10 Jul 12 23:08
many thanks will look in to in more detail
Paul
Close Box
Join Eng-Tips® Today!
Join Us             Close
